briggs new engine
gardendummy
10-16-2005 17:50:26
i'm looking at a scag 0 turn mower. it has a new model briggs and stratton 18 hp engine. does anyone have an opinion on this engine vs kawasaki or honda? it's priced about 1000 dollars less than the same machine w/these engines.send
Jim_bobb
10-22-2005 07:42:23
 Re: briggs new engine in reply to gardendummy, 10-16-2005 17:50:26
$1K is a lot of money. Nothing wrong with a B&S engine.
Robert in W. Mi.
10-20-2005 17:40:42
Exactly what Briggs engine is it???? They have at least 3 quality levels with the Vanguards being the best.
If the Briggs is a Vanguard, then i'd save the $$, if it's one of the other models then i'd go with the Honda or Kawasaki.
That is if your going to keep the mower a LONG time!
Robert
JT
10-18-2005 06:10:58
The 18hp Briggs Intek is a good engine. If you are going to use it commercially, you might consider the other two, but if you are a homeowner, the Briggs will suit you fine for a lot of years if you know what oil, oil filter, grease guns are for and keeps your blades sharp so you do not pull it hard all the time
BigBill
10-16-2005 18:24:23
While the Kaw or Honda may be a little better engines I don't see them being $1,000 better. As long as you maintain it properly the Briggs should last fine.
