air compressed engine, please help
oldtractorguy
09-09-2005 12:32:39
I built a small air compressed engine. It is piston driven. The block crank shaft cylinder and piston and rod are from a cox 0.049 engine. I ran it with a 12 volt air compresser. It ran for 20 0r 30 seconds with a fly wheel. Please help.
Vern-MI
09-09-2005 18:41:52
 Re: air compressed engine, please help in reply to oldtractorguy , 09-09-2005 12:32:39
OTG is this a joke or what? You built a compressor from an old model airplane engine? What are you going to do with that little runt anyway? That thing will overheat in a flash if you ever really develop any pressure at the output. The con rod in that thing is like a toothpick and ready to give up if worked hard. All that said you must minimize the head volume in order to increase the pressure so start there. The check valve must be in the head and be made so as to reduce the back pressure when pumping. Remember that the work that the pump must do is the sum of all the series backpressures in the system. Maybe you should add liquid cooling and a radiator. Sounds like something for the Yack Arena during the modelmakers show in April.
oldtractorguy
09-09-2005 20:32:16
 Re: air compressed engine, please help in reply to Vern-MI, 09-09-2005 18:41:52
I used a compressor to power the cox.
oldtractorguy
09-09-2005 20:30:17
1 ran for 25 to 30 minutes strait, and nothing overheated.
Vern-MI
09-10-2005 14:33:48
 Re: air compressed engine, please help in reply to oldtractorguy , 09-09-2005 20:30:17
What are you doing with the .049 other than just motoring it with your compressor? What was the pressure at the inlet to the .049? What speed did it run at for 30 minutes and what was it driving. Are you making a compressed air driven model of some sort. Those little engines need lubrication and as I recall they don't have piston rings.
oldtractorguy
09-11-2005 05:42:39
 Re: air compressed engine, please help in reply to Vern-MI, 09-10-2005 14:33:48
10 to 12 pounds. I plan to power a old gas powered car with it.
Bob
09-11-2005 10:06:31
 Re: air compressed engine, please help in reply to oldtractorguy , 09-11-2005 05:42:39
What are you using for valves to convert the original 2-stroke-cycle compression ignition engine to an air operated motor?
If you want to run it on air, why not use a little steam engine?
gene (missouri)
09-09-2005 17:57:55
Bigger air compressor - more volumn??
Gene
Larry-IN
09-09-2005 13:02:00
Help with what?
oldtractorguy
09-09-2005 14:48:59
 Re: air compressed engine, please help in reply to Larry-IN, 09-09-2005 13:02:00
i need help to find out how to get high compression.
