amp meter
Don c
07-14-2005 11:17:28
Cub cadet 128, starter-generator combine, amp meter jumps all over the place, it is charging. Is there something I can put in to keep it from jumping so bad. Thanks
Bob
07-14-2005 12:04:51
 Re: amp meter in reply to Don c, 07-14-2005 11:17:28
Check the rubber mounts on the regulator, as excess vibration will affect the regulator.
Also, there is a bare stranded ground wire that jumpers around the rubber mounts for ground continuity. If that is broken, and the regulator only gets grounded once in a while as it vibrates around, that will make the needle jump.
If those items check out OK, you'll either have to live with it, or try a new regulator. (In my opinion, a certain amount of needle movement is NORMAL, with these old mech. regulators.
