bs 5hp woodsplitter stall after warm up.
bcPA
07-12-2005 19:56:53
after about 10 minuites of careful use the engine will stall even though I am taking it very easy on the splitter. This splitter was bought new from sears around 1977. One owner and has never given any trouble till now. I took off and cleaned sheetmetal to ensure good air flow. What is next. THANKS.
shannon from ohio
07-13-2005 17:13:14
 Re: bs 5hp woodsplitter stall after warm up. in reply to bcPA, 07-12-2005 19:56:53
Sounds like governor problems? Check spring and linkages for wear,binding ,etc.You may have to readjust these BUT NEVER higher than 3600-3800 rpm
spank monkey
07-15-2005 06:41:09
 Re: bs 5hp woodsplitter stall after warm up. in reply to shannon from ohio, 07-13-2005 17:13:14
Check your vent in your gas cap to make sure there is no obstruction.
