ariens YT11 transmission problem
jim thomson
06-30-2005 02:57:16
i have an ariens yt11 tractor, the halfshaft drive gears/diff gears have worn to the point of slippage. can anyone advise if parts for this transmission are available? is the transmission common to other makes eg. wheelhorse? any help on this subject would be most welcome,jim
SteveMac
09-05-2006 21:05:22
 Re: ariens YT11 transmission problem in reply to jim thomson, 06-30-2005 02:57:16
Jim I broke an axle on that tractor and the Ariens solution is to buy the complete Axle transmission unit as one piece and replace it. It is about a $150 part and will replace all of your gear problems - as they are all new. Most Ariens dealers will have access to order this for you.
JT
06-30-2005 12:07:54
Jim Post the model of the tractor and I will see what I can find.
Jim
jim thomson
07-06-2005 12:17:53
 Re: ariens YT11 transmission problem in reply to JT, 06-30-2005 12:07:54
thanks for your reply, the tractor ser. no is 002416, model no.935005 it has 6 speed box previous history unknown thanks in anticipation jim.
