bolens oil seal#
Joe Bloggs
06-10-2005 15:36:35
once again I am here asking for help. I am working on a bolens 770 it has a 3 speed transaxle. I dont know who made the axle but it has a tag with the numbers 1207 006299. what I need is a part number for the oil seal at the axle. there is no numbers on the one that was in there. the whell was loose on the axle and has worn away the outside of the seal.
Bob
06-10-2005 23:20:44
 Re: bolens oil seal# in reply to Joe Bloggs, 06-10-2005 15:36:35
A place like NAPA, or an idustrial bearing and seal place should have no trouble finding you one, if you have the bore size, shaft diameter, and seal width.
oldrustycars
06-11-2005 12:12:14
 Re: bolens oil seal# in reply to Bob, 06-10-2005 23:20:44
if there's a Berry Bearing near you, (now called Motion Industries) they can fix you right up, as been stated, with the dimensions. use calipers to get EXACT measurements. also, isnt bolens now troybilt? i seems to recall them saying all parts would still be available.
