honda 4514 hydrostatic problems
Eric L
05-12-2005 05:46:10
Hy! i have a honda 4514 hydrostatic lawn tractor. My problem is that when its been in use for about 15-20 minutes it wont climb a small hill. I changed the hyd oil and it helped a bit but still have the problem. I think the problem could be the hyd pump. Did someone experienced this problem?
billyconn
05-31-2006 17:35:28
 Re: honda 4514 hydrostatic problems in reply to Eric L, 05-12-2005 05:46:10
white smoke coming from exhaust and oil found in air filter housing,and carb just trying to confirm it is a headgasket problem
Farmall Teen
05-12-2005 17:07:26
Does it have enough oil? The filter could be pluged or some seals are going or gone.
My to cents
DCR
05-24-2005 08:37:12
 Re: honda 4514 hydrostatic problems in reply to Farmall Teen, 05-12-2005 17:07:26
I have the same problem with my 4514. At this point I am replacing the trannie with a used one. Is this a worth doing and do yo have any suggestions on trouble shooting the broken trannie?
Thanks
ericl
05-24-2005 15:21:15
 Re: honda 4514 hydrostatic problems in reply to DCR, 05-24-2005 08:37:12
I ordered a shop manual for my tractor and i am waiting for it but i think it is the hyd. pump that has an internal leak. I will figure out later. will keep you informed with what i find.
DCR
05-25-2005 07:22:49
 Re: honda 4514 hydrostatic problems in reply to ericl, 05-24-2005 15:21:15
I am picking my trannie today. I am trying to locate a simple schematic of the trannie. On another subject do you know if any other Honda engines are interchangeble with a 4514?
Thanks
ericl
05-26-2005 19:26:23
 Re: honda 4514 hydrostatic problems in reply to DCR, 05-25-2005 07:22:49
I dont know if any other engine would fit but maybe one from a 4518. If you can find a schematic of that trannie could you e-mail me a copy i would appreciate.
DCR
05-27-2005 05:32:42
 Re: honda 4514 hydrostatic problems in reply to ericl, 05-26-2005 19:26:23
I will contact the local Honda dealer but they keep a lot of information close to thier chest.
