JD 212 tranny..need gears and spring
Gregg in ohio
05-06-2005 19:41:59
got the 212 home,with a like new snowblower all it had was 3rd gear..split the cases and 3 gears were gone and the 1 2 shift detent spring was broke..any used parts out there..110 112 210 212 214 216 should interchange..cant see buying a used tranny unless the price is right and its close to home in ohio.cant drive far with my bum back...otherwise ill rebuild it with some used gears..thanks gregg in ohio
stronics
05-07-2005 04:42:20
 Re: JD 212 tranny..need gears and spring in reply to Gregg in ohio, 05-06-2005 19:41:59
Gregg, what gears do you need? I may have some but I've used 4 out of a 2300 series. I may have a contact for another complete trans for parts.
How are the rest of the gears? Is the inside clean?
David
Gregg in ohio
05-07-2005 06:20:10
 gears in reply to stronics, 05-07-2005 04:42:20
i will take a inventory of broken gears and a couple that are questionable..its clean now i just cleaned it in the parts washers,,eee gad the oil was the uglyest brown cokor..anyway ill get a list of what i need..i can get the detent sprongs at the dealer..im going to replace the other one also before it breaks..thanks gregg
