high idle
t
04-25-2005 17:28:31
I have a lowes tractor. When i start it up it revs up real high and stays there. When you give it some throttle it does nothing and it stays at that same rev point. I anint sure whats wrong with it.
don watts
04-25-2005 17:49:33
 Re: high idle in reply to t, 04-25-2005 17:28:31
has anyone fooled with the linkages or took it off and put it back on.it sounds like the likages may be hooked up backwards.if not check that carb butterfly to see if it not stuck wide open .if so spray it with wd 40 and work it back and foth by hand to make sure its moving.another thing did you or anyone screw the idle screw in .just tryin to ask some questions to see if thats not part of the prob. don
