JD LT155 starter keeps turning
roman nose
04-10-2005 16:05:15
John Deere LT155 starts but when it does the starter disengages but keeps spinning for about 15 to 30 seconds then stops--any idea what the problem is? thanks
don watts
04-11-2005 06:02:40
 Re: JD LT155 starter keeps turning in reply to roman nose, 04-10-2005 16:05:15
sounds like the starter solenoid is hangin up.or could be the switch needs replacing.sounds like when you hold key over to start when u release the the key from start to run position its stayin hung in the start position.hope that helps .good luck.
