allis B10 grinding
Joe Bloggs
04-06-2005 18:38:28
I have an allic chalmers B10 or big 10 lawn tractor. it runs ok it goes foward ok but when I change to reverse it grinds when I let the clutch up, just for a bit then runs ok . it grinds again when i try to go foward. so basicaly it grinds on change of direction. any one know about this.
Jim K
04-09-2005 18:34:41
 Re: allis B10 grinding in reply to Joe Bloggs, 04-06-2005 18:38:28
Hi Joe I have the same machine and it does the same thing. I haven't really looked to see where the noise is coming from but I think that it is coming from the clutch type lookin thingy mounted on the output shaft of the bevel gear box.
It is supposed to slip when the gearbox is over loaded.
arjr111
04-08-2005 16:02:20
Go to the simple tractors site and search Bevel Gear Box. Or BGB.
Dannie
04-07-2005 17:32:24
Check the variable speed pully for wear .
Karl Brandt
04-07-2005 12:12:57
Sounds like you need to adjust the clutch or need a longer belt.
When the engine is running push the clutch all the way down and look to see if the transmission pulley is turning.
I also have a Allis Chalmers B-10 and more.
Karl
Joe Bloggs
04-07-2005 18:06:52
 Re: allis B10 grinding in reply to Karl Brandt, 04-07-2005 12:12:57
I like your page. now for my problem. the grinding is not when changing gears it happens after i let the clutch up. the tractor will start to move then the grinding noise happens then its ok as long as I keep going in that direction. no mater what gear I am in. it wont hapen on changes in forward gears only from forward to reverse.
stronics
04-07-2005 05:09:21
I'm taking a guess here. I think it could be a loose pulley some where or slop in the transmission.
David
