bolens husky efficianados
Joe Bloggs
12-25-2004 18:22:47
I have a machine i need to identify. its a bolens husky has a 8hp briggs virtical shaft engine.runs a belt drive snow blower off the front at the front of the machine it has a pulley on a virtical shaft. so it belt drive pto.there is no identification on this machine that I can find. the rear wheels are keyed onto the axle, there is no wheel nuts/bolts.
what I need is help to get the pto working. the lever has engage /disengage but nothing underneath moves. I am looking for a picture of how it should look or a parts diagram.
there is an idler pulley on a long rod that should move into position to tighten the belt. I can move it easily by hand and it works fine but it wont work from the lever.
any one know what I am talking about?
Joe Bloggs
12-25-2004 19:02:27
 Re: bolens husky efficianados in reply to Joe Bloggs, 12-25-2004 18:22:47
as best as I can tell looking at little pictures I find on ebay it looks like a 770. but I cant be sure
PA parts
12-25-2004 18:37:47
Sounds like you've got a model 813. You make find some diagrams here : Link or there was a Bolens group on Yahoo. I'm not real familiar with the vertical shaft models so can't help you much otherwise. My guess would be there is a rool pin though that shaft that's sheared somewhere if they are setup like the bigger ones.
