allis B10 extra wheel bolts in hub??????????
Joe Bloggs
12-02-2004 14:01:41
I have a allis chalmers B10 from 1967 I just changed the right rear wheel I could not get it off untill I had removed the two bolts in the center of the hub. the look exactly like the bolts that hold the wheel on. are they spares or do they serve a purpose.
Karl Brandt
12-04-2004 04:08:05
 Re: allis B10 extra wheel bolts in hub?????????? in reply to Joe Bloggs, 12-02-2004 14:01:41
I also have a Allis Chalmers B-10 tractor and many more.
The tractor is equipped with a controlled traction differential.Tightening the hex head capscrews in the right hand wheel hub,provides pressure against a nylon plug and sleeve around the tractor axle and prevents exessive wheel slippage when the tractor is being used under abnormal slippery conditions. The adjusting capscrews are set at the factory to a torque of 25ft.lbs.As the nylon sets itself through use,it may be necessary to readjust the capscrews a few times to maintain 25ft.lbs.of torque.
