So what did you do when you backed the wire off the plug? You allowed the voltage output of the coil to build to a higher value before it was absorbed in firing the plug. So what builds the voltage higher in the coil otherwise? The Voltage across an inductor is produced by L di/dt. Which is the inductance of the coil times the change in current divided by the time in which all this occurs. So what can affect what? If the coil had shorted turns, it wouldn't have the correct value of inductance (L). The output voltage would be low. To switch the current at the given rate, you need a switch capable of doing that. If you have an electronic ignition module that is semiconductor driven, the semiconductor could be lazy or not getting the correct drive. This would produce a lower than normal current and resultant low voltage. If it was a point condenser thing, the points could be pitted or the condenser could be leaking (partially shorted) bypassing the snap action of the points. If the condenser slows this interruption enough, there is no interruption (so to speak) and no output voltage produced. Since you were able to increase the gap, and the engine ran fine, the coil apparently operated satisfactorily at a higher voltage which suggests that there is not an internal short. That leaves the switching mechanism...ignition module (points or condenser/scr whatever). Or, there is something about the plugs that allow the charge to bleed off before it gets to a high enough potential for sufficient plug firing. I would first think of dirty insulators, but having changed them twice, doesn't lend it'self to being the problem. Course dirty plugs could very well be the problem caused by excessive fuel, which also causes black sooty smoke, caused by an improperly set float valve. Or a SLOPPY FLOAT LIKE IS PREVALENT NOWADAYS WITH NYLON SUPPORTS RATHER THAN BRASS. The nylon allows the float to rise to the top of the bowl without supplying adequate pressure to the inlet needle valve and shutting the fuel off. Gapping the wire just made a gap (which you apparently didn't have in the plug due to dirty insulator bleeding voltage off before it could jump the plug gap) allowing the coil to get to voltage which it couldn't when black sooted insulators were bleeding it off. Been there done that. Nuf Said.....now that you are probably totally confused. Start with the float (and clean plugs) then the switch (ign module) and last the coil. Mark
