briggs gas tank
roman nose
11-01-2004 04:05:38
I have a briggs 5hp with a pulsa jet carb. The tank is filled with some kind of sponge material. Is this some kind of filter or can I remove it?
JT
11-01-2004 06:16:07
 Re: briggs gas tank in reply to roman nose, 11-01-2004 04:05:38
you can get rid of that foam, it causes more problems than it solves.
chad
11-01-2004 04:42:48
They put the sponge stuff in there to keep fuel from moving around while turning. Like on mini bikes and go-carts.
roman nose
11-01-2004 04:50:53
 Re: briggs gas tank in reply to chad, 11-01-2004 04:42:48
thanks Chad, I guess I don't need it then because it is on a log splitter. It will only run on choke so I have to try and clean up the carb. I thought maybe that foam stuff was blocking the fuel intake
txblu
11-01-2004 09:36:59
 Re: briggs gas tank in reply to roman nose, 11-01-2004 04:50:53
Cute handle. I too have one of those..... .Roman noses. Never know what people will use for it.
Mark
