JD 214 choke
Karl Grindley
10-23-2004 15:50:02
My 214 will only run with the choke pulled out. As soon as you push it in, no mater how hot the engine is, it dies. Any ideas?
Thanks, Karl
lucas boy
10-23-2004 17:26:27
 Re: JD 214 choke in reply to Karl Grindley, 10-23-2004 15:50:02
dirty carb or fuel pump...lucas
catmandoo
10-23-2004 18:27:10
 Re: JD 214 choke in reply to lucas boy, 10-23-2004 17:26:27
the condition you describe is running lean,and it is usually dirt in a jet in the carb or the gasket between carb and block.or as lucas said a fuel pump.also the throttle shaft on those kohlers can get really loose also, causing this condition,if thats the case they make a repair kit to tighten up the shaft.
