is it ok?????
Nathan in OK
09-28-2004 12:55:51
I was pulling some small logs with my john deere 112L hydro,I moved them to where I wanted them, and stoped the tractor(did not shut the eingine off)I toke the rope off, got back on the tractor it would not move!!!! I shut off the eingine and am letting it set right now. did i brake it????? did it get to hot???
Thanks Nathan
txblu
09-29-2004 07:00:23
 Re: is it ok????? in reply to Nathan in OK, 09-28-2004 12:55:51
May be a spring came off the drive belt.
Let my grandson play on my mower (blade off) in a field. Was going up a hill and did something cause it started rolling down and he could do nothing about it.
Got it to the shop and one of the springs on the drive belt tensioner pulleys popped off. Put 'er back on and had no problems since. Course he doesn't ride it anymore either.
I am careful with my hydro as I am concerned that heat from pulling things may kill it. Also insure that the top of the tranny is clear of grass clippings and that the little belt driven fan is a fannin.
Mark
Nathan in OK
09-29-2004 08:00:15
 Re: is it ok????? in reply to txblu, 09-29-2004 07:00:23
Fixed it, the belt came off the drive. thanks for the help guys.
Thanks again, Nathan
txblu
09-29-2004 09:44:57
 Re: is it ok????? in reply to Nathan in OK, 09-29-2004 08:00:15
Great!
Dannie
09-28-2004 13:27:19
I would check the belts and pulleys,make sure you did not somehow pull the free row device.
