bacfires and will not start
jfh
09-12-2004 09:33:22
Kohler 14hp won"t start backfires through carb. When I took carb off to clean there was vacumn released for the carb. Any help out there.
txblu
09-15-2004 09:11:59
 Re: bacfires and will not start in reply to jfh, 09-12-2004 09:33:22
Have even had key (Woodruff) half cut into and it wouldn't start. Pull the flywheel and check. Amazing how sensitive the timing on these engines is.
Have you hit any obstacles hard lately? Usually that't what does it. The blade hits an obstacle, stopping the crankshaft, but the flywheel is a lot of mass and it keeps going.....damaged, broken woodruff.
Mark
MAC,IL
09-13-2004 06:35:54
Might look at flywheel key for a start.
walt
09-12-2004 18:31:36
Normally backfire means timing is off.ie, spark not at the right time with compression.
