back fire now no spark
Maynard
08-17-2004 14:32:45
Kohler K321 with electronic ignition.
Backed in shed at idle which takes about
one minute. Shut it off and it back fired.
Now has no spark. Spark plug is wet with gas
when remove . Change plug it is also wet when removed.
MAC,IL
08-17-2004 16:32:08
 Re: back fire now no spark in reply to Maynard, 08-17-2004 14:32:45
Check the flywheel key before you do anything else.
don
08-17-2004 16:04:26
sounds like the solid state ignition module is out .also chk flywheel key.see if its sheared.
