big simplicity tractor..what model is it
dean
08-03-2004 21:02:19
found a simplicity with about a 20 or so hp onan and hydrostat along with a gear shift and shuttle shift transmission...3 pt hitch ...54 in 3 pt mower deck that operates off of the pto..4 ft blade and moldboard plow..what model is this..are they any good to use for mowing?..whats it worth?...thanks
Don
08-06-2004 18:40:02
 Re: big simplicity tractor..what model is it in reply to dean , 08-03-2004 21:02:19
Sounds like and looks like a brother to the AC720 alot of them still running around mowing football fields and commercial work, most of them running around with 60" decks. If I didn't already have a big mowing tractor I'd have one in a heartbeat. I've got a close friend who collects them. I think he has all the implements too. Gotta keep the grass blown out of the cooling fins and they'll run forever.
Lou
08-04-2004 14:57:51
Where is it? If you don't want it, I might.
Kent
08-04-2004 11:36:10
 It's a PowrMax in reply to dean , 08-03-2004 21:02:19
third party image
These are VERY desirable old machines. Some had optional Category 0 3-point hitch and 2000 RPM rear PTO. It was one of the very first in what is now called "Compact Tractor" size....
It's one of the best mowing tractors of that size ever made, IMO. Here's more info on the newest version of that tractor, a Model 9020. You may want to spend some time on this site, researching it...
JT
08-04-2004 07:19:58
If the engine is in good shape, and everything else is in good shape, it could be worth up to 2500-3000.00. Is it good for mowing??? YES, Simplicity makes one of the better graden tractor that can be bought. Onan engines are now owned by Linimar, they have made engines and generators for years. If it has had decent care, they are good engines. For more info, there is a Simplicity web sight, not sure what is is, something like www.simpletractors.com or something like that.
Kurt (mi)
08-04-2004 02:18:23
If it is in good shape then I would say about $500+ I dont know the model you need to find that out. Onan is japanese I think.
