b s 12,5
plotts
08-01-2004 04:48:02
Older type motor has points. Put new pionts in had starting very easy. Removed to do other work . Installed later now i can;t get to fire; How do i replace points with late model coil?
JT
08-01-2004 09:12:29
 Re: b s 12,5 in reply to plotts, 08-01-2004 04:48:02
if it is a cast iron engine, you cannot do this without changing the flywheel, the polarity is wrong on the f/w. if it an aluminum block or cast iron sleeved block and has a 2 legged coil, you can put a solid state on it, give me your model number and I will look and see what coil you will need.
Dannie
08-01-2004 08:49:00
Engines before 1981 cannot be changed over .
ANON
08-01-2004 13:04:53
 Re: b s 12,5 in reply to Dannie, 08-01-2004 08:49:00
better check that again, I have changed many over to the solid state coil and they all worked including a 13HP cast iron briggs without changing the flywheel! Just had to reshape the two poles to the same radius as the flywheel.
JT
08-01-2004 13:37:57
 Re: b s 12,5 in reply to ANON, 08-01-2004 13:04:53
you are a very lucky man, the flywheel on the cast iron engines need to have the polarity reversed if had points and condensor from the factory. That is a fact from Briggs & Stratton Corp.
ANON
08-01-2004 18:46:34
 Re: b s 12,5 in reply to JT, 08-01-2004 13:37:57
It's been running for 2 years now-no problems
