carb floods on 8hp hohler engine
Virgil
07-05-2004 19:41:25
Carburator has new kit and float has been adjusted. Someone has replaced fuel pump. Can the fuel pump have to much pressure. Possable wrong pump. Carburator is overflowing just like needle/seat or float problem.
KennyW
07-07-2004 10:05:04
 Re: carb floods on 8hp hohler engine in reply to Virgil , 07-05-2004 19:41:25
There are different fuel pumps with different pressures. Try to gravity feed the carb first to tell whether excess pressure is keeping the needle off the seat causing the leaking.
Chad
07-07-2004 04:56:09
You have probrably replaced the float needle but the seat that the needle goes against might have deposits or be worn and i would replace this.
07-06-2004 19:06:09
Could your gasket in the carb bowl be leaking, that is if it leaks around the top
Chad
07-06-2004 05:07:18
Make sure float does not have a hole. Just shake it.
Virgil
07-06-2004 18:02:18
 Re: Re: carb floods on 8hp hohler engine in reply to Chad, 07-06-2004 05:07:18
Put new float in it today. Set it upjust like directions. Engine ran longer than it has before. Wont stay running under load.Mail fuel adjustment screw irratic to adjust.Still floods out when it cuts off.Fuel soaks air filter and runs out on ground.Help....
