valve setting, Kohler
Don c
06-30-2004 07:27:28
Need cold valve settings for Kohler K301A 12 hp.
Thanks Don c
KennyW
06-30-2004 13:08:03
 Re: valve setting, Kohler in reply to Don c, 06-30-2004 07:27:28
I call it Valve Lash
Bob
06-30-2004 09:25:55
Tappet setting cold is:
Intake: .008" to .010"
Exhaust: .017" to .019"
On these engines, the tip of the valve tends to wear a recess in the top of the tappet adjusting screw over time, which makes accurate tappet clearance adjustment with a feeler gauge impossible. If you now have the engine apart, check for this wear and replace the adjusting screws, if needed, or have a machine shop grind the screw flat for you.
Do youself a favor, and download a shop manual for free at:
http://www.kohlerengines.com/pdf/tp-2379.pdf
R Bedell
06-30-2004 08:40:00
What do you mean by "settings".....?????
JT
06-30-2004 10:26:48
 Re: Re: valve setting, Kohler in reply to R Bedell, 06-30-2004 08:40:00
Settings are commonly referred when talking of clearance between the valve and lifters, or clearance on points, flywheel air gap, etc.
R Bedell
06-30-2004 12:10:03
 Re: Re: Re: valve setting, Kohler in reply to JT, 06-30-2004 10:26:48
Terminalogy....!!! LOL
I simply refer to that as "the gap".
I wasn't for sure if he was talking about the Valve Spec's, ie: Diameter of the stem.
JT
06-30-2004 16:54:00
 Re: Re: Re: Re: valve setting, Kohler in reply to R Bedell, 06-30-2004 12:10:03
hey, you'd be surprised at some of the terminology I get from people in my shop
Ben in KY
07-01-2004 12:05:02
 Re: Re: Re: Re: Re: valve setting, Kohler in reply to JT, 06-30-2004 16:54:00
Yeah how far from the thingamajig is the whatchamacallit supposed to be :)
