help removing mower deck blades
Grego
06-19-2004 12:08:12
Before I hit the bolts with my impact wrench...
are they left or right hand threads??!!
The deck in question is on an MTD 800 series garden tractor, my little utility basher.
It is a 48" three blade deck, prior to their conversion to star washer/bolts.
Thanks in advance, grego
MAC,IL
06-19-2004 16:17:31
 Re: help removing mower deck blades in reply to Grego, 06-19-2004 12:08:12
leftie loosie, rightie tightie. Why do you need an impact wrench for bolt removal?
grego
06-19-2004 22:03:03
 Re: Re: help removing mower deck blades in reply to MAC,IL, 06-19-2004 16:17:31
An impact wrench losens the bolt without
needing to work as hard to hold the blade.
This one doesn't have a backing nut or
other handy way to hold the blade from
turning. Besides the driver is handy.
Virgil
07-05-2004 20:00:45
 Re: Re: Re: help removing mower deck blades in reply to grego, 06-19-2004 22:03:03
A die grinder to grind off head or nut may be helpful. These deck bolts can be rough because if the deck is worn out the bolts are too.
Dannie
06-19-2004 13:55:44
Right hand
