case 155 aux hydraulics
smark
04-28-2004 19:06:58
Is it possible to hook up Hydraulic connectors to run equiptment off my Case 155 Hydromatic? Any idea what the GPM would be? Where would I connect into the lines?
Jim
05-04-2004 22:44:51
 Re: case 155 aux hydraulics in reply to smark, 04-28-2004 19:06:58
Yes, the GPM for that pump was about 8. The hydraulics that were added to that tractor over the earlier model 150 were hooked up coming out of the directional control valve heading toward the hydraulic cooler. You can patch into this line, but your pressures will be down from the 2000 psi going in. Jim
