high duty front hubs
RusselAZ
04-28-2004 18:55:19
As one who is always on the prowl for better or different ways of doing things I found this use this week for a car part.
The rear hub and bearing assemblies for a 2000 ford escort will work on the 4 bolt 4 inch pattern 4.00X8.00 wheels for garden stuff. Namely, they are an easy mod for the front of a garden tractor that is using a front bucket. They cost about 40.00 and come with hub, studs and bearings. The bearings are preloaded so you can put them on a 1 3/16th shaft and tighten them down or just cotter pin them. I'm sorta anxious to build them up for my old sears but I'm going on vacation for a couple weeks. The price is maybe more (not much) than what you can buy the ones for with tapered bearings but these are pretty one piece self contained.
Shannon
04-30-2004 21:41:14
 Re: high duty front hubs in reply to RusselAZ, 04-28-2004 18:55:19
I'ts like different types of projects I do at the shop using automotive parts.Take this one into consideration.....You need to make a lawnmower or other kind of trailer but don't know what kind of axle to use??? Simple, go to your local salvage yard and get a rear axle assembly from a dodge minivan or plymouth voyager... Make nice units,plus leaf springs are attached to axle.....
Best wishes Shannon...
