: : : Although this is not a question about a "Yesterdays tractor", I'd still appreciate some help. What causes my garden tractor to run off the battery? It seems to have started doing this lately, and it's becoming a pain to jump start it every time I want to use it. : : : Any ideas?: : : Thanks, Chris : : If it's depleting the battery, that generally means your alternator or generator isn't working correctly. What make/model tractor do you have? An older model may have a generator with a loose belt which doesn't let the generator spin fast enough to charge. A lot of these had a starter/generator in one unit, so if it starts, the belt is not likely the problem. Do you have an ammeter on the tractor? If so, does it show slight charge, no charge, or discharge? Check all connections to the battery, generator, alternator, and everything else to make certain they are CLEAN and tight. A dirty battery connection will sometimes let you "jump" the system from another vehicle without really taking much of a charge, thus letting your tractor run on what is being produced by the alterator or generator without putting anything back in the battery. If you have a battery charger, connect it to the battery and see if it takes a charge well. A faulty cell in the battery could be your problem if it won't. Also, make : : sure you don't have something left on to discharge the battery between uses. If it starts and runs okay for long periods from a jump, it's likely generating electricity, but not storing it! : Thanks for the input. My problem is that I don't see/have an alternator or starter/generator combo, just a starter. The tractor in question is an early '80's Ford LGT 165, w/16 HP Kohler. The ammeter shows a discharge condition when running. When jump started, the tractor runs fine as long as I need it to, I just can't restart it after I turn it off. It has developed another interesting symptom: When the battery depletes itself far enough, the PTO will quit working. I assume this is some kind of fail-safe to save power so the tractor will still run as long as possible. I guess the real question here is what device is responsible for charging the battery on my tractor, given that there is no identifiable alternator or generator??? BTW, there are no switches left on, as the only ones on the tractor are the PTO and the lights. I must be missing something simple. The owners manual is no help. : Thanks, Chris Chris: - the alternator on your engine consist of a stator ring of coils mounted behind the fly wheel. Depending on the model, they only put out one or a few amps so it is very important that all connections are good and the battery is good. Follow the other guys check list and remember that if any one of these things is a weak spot it won't charge. Your PTO is stopping simply because your battery can no longer power the electro-magnetic clutch. Running it with the battery down can cause it to slip and wear badly. Good luck.
