White GT2055 - attachments available
Les Y.
03-13-2004 09:56:22
I just picked up White GT2055 (20 HP Garden Tractor) that's a few years old, and would like to pickup a rototiller and a post hole digger for it. It has a class0 3-PT hitch and PTO. How do I determine what attachments would work with this tractor? Any help would be appreciated.
Steve Mahler
03-15-2004 08:02:57
 Re: White GT2055 - attachments available in reply to Les Y., 03-13-2004 09:56:22
The most important thing to figure out is the speed and direction of the PTO - some Cat 0 PTOs run counter clockwise, some run at high speeds. Either will present a challenge for you. If I had to guess, yours will run clockwise (good) and fast - like 2000 rpm (bad).
That will limit the availability of tillers that will work. It is relatively easy, though not cheap, to find a 540 RPM tiller. Keep in mind you could always convert a Cat 1 tiller (48 inch wide or less) to Cat 0 - the main issue there is making sure you have enough lift power to get the thing off the ground.
