huskavarna
ray
03-04-2004 16:21:08
have 15 hp holer engine runs but got a rappinp in the front does any body know what it is its a 96 yth model thanks for any help
John McPherson
03-04-2004 16:46:15
 Re: huskavarna in reply to ray, 03-04-2004 16:21:08
Try turning the engine over by hand to see if you can feel the interference, and possibly isolate the point in rotation of the crankshaft, or if the rapping should be accounted for by something moving at a different speed. This is assuming that the knocking is coming from the engine as description isn't isolating noise to the engine.
It is very possible that the connecting rod bolts have worked loose and need to be addressed. There is a small chance that the upper crankshaft bearing and or journal have worn enough to allow the flywheel to contact the magneto, or other external protrusion close to the flywheel, even a shroud bolt that is too long may contribute to this.
It might also be bent crank and or pulley if the intereference is noted externally.
At this point, do not run it any more until the problem is located and fixed. At a minimum, you do likely need to pull the engine if an external source for the interference is not found.
ray
03-05-2004 11:48:02
 Re: Re: huskavarna in reply to John McPherson, 03-04-2004 16:46:15
john one of the rocker arms is loose all the time and other is tight and feels like the pulley for belt is comming apart but i would have to take snow blower off to confrime that it has electric clutch on it
John McPherson
03-05-2004 13:21:07
 Re: Re: Re: huskavarna in reply to ray, 03-05-2004 11:48:02
a loose rocker arm is good bet for some noise at half crankshaft speed. Also a tight one too if the valve is actually hitting something, even hard carbon.
If the pulley looks to be pulling apart, that too can be a source of knocking noise, and that would be at the speed of the shaft it is attached to. There may even be a visible bright spot on a high portion where it is hitting if it is actually off center and off true.
ray
03-06-2004 09:20:00
 Re: Re: Re: Re: huskavarna in reply to John McPherson, 03-05-2004 13:21:07
i checked the push rod not bent was told to change oil and put a bit of tranny oil to try to free up hydruilic lifter do you recommed that or no
