cadet creeper grear
Larry
01-21-2004 07:50:42
How difficult is it to install a creeper gear in a cub cadet 125 mdl.
Phil B.
01-22-2004 08:05:13
 Re: cadet creeper grear in reply to Larry, 01-21-2004 07:50:42
The creeper was a dealer installed option. You obviously need the creeper trans. and also the pinion gear that will go on the 3 speed trans. input shaft. You can cut your existing driveshaft with a hack saw and re drill the hole for the spirol pin that goes through the coupler. I've seen creepers on e-bay go for as high as $250.
I've bought a couple from guys on the Cub Cadet forum sites though for cheaper.
Bill
01-21-2004 18:40:40
Not a real difficult job - IF you get all the pieces you'll need. Will need driveshaft out of creeper tractor ( or have yours shortened) as well as couplers, shift lever,etc. I would try to get everything from one source if possible. They were all basically equiped so this option could be added from the factory. I thinks Mike is a little optimistic though on price. I'd expect closer to $ 200
Larry
01-21-2004 13:27:22
I have two cadets one is a hydro and the other is 3 speed. wrong model number ; anyway I would like to know how much of a project it is to put a creeper gear in ; if I can find a creeper gear.
mike
01-21-2004 16:04:35
 Re: Re: cadet creeper grear in reply to Larry, 01-21-2004 13:27:22
watch ebay,see them there on occasion for 75-100$
Rick
01-21-2004 09:02:47
The 125 only came out as a hydro. Why would you want to put a creeper on a hydro?
mike
01-21-2004 11:19:15
 Re: Re: cadet creeper grear in reply to Rick, 01-21-2004 09:02:47
to slow it down
Guest
01-26-2004 16:55:57
 Re: Re: Re: cadet creeper grear in reply to mike, 01-21-2004 11:19:15
Creepers will only work on gear drive transmissions. Hydrostatic drives provide "infinite" speeds, so no creeper required.
