int. cub cadet 154 low boy
mike
01-09-2004 18:02:22
just bought a 154 with mower deck. paid $400, only thing wrong as far as i can tell is the fuel bowl gasket needs replaced. what else was made to use with this tractor? it has a draw bar and a plate on the back where a pto would hook up on a larger tractor. any help, would be greatly appreciated. thanks in advance.
Gene Davis (GA.)
01-11-2004 20:18:05
 Re: int. cub cadet 154 low boy in reply to mike, 01-09-2004 18:02:22
You have to watch these tractors, the 154 I had was equipped with an independent P.T.O., shaft,BUT!!!! the thing was a counter clockwise rotation,(read that as backwards)!!!! The diameter was 15/16 instead of the standard 1&3/8 6 spline shaft. These tractors have to have special implements and you will need a sack of gold to keep it running. Speaking from experience on this, they are pretty much large lawnmowers! Gene Davis
