LT133s
Vern
12-23-2003 22:23:20
Does anyone else have a JD LT133? I hope I don't have the only one but I never see anything about them here.
Mine is about 3 years old & runs great. It has the 13hp Kohler engine. The only problems I've had with it is the 38" mower deck.
john669
12-24-2003 15:22:13
 Re: LT133s in reply to Vern, 12-23-2003 22:23:20
The LT133 is basicaly the same as the stx38. the black deck on them, some say is not as strong as the yellow one, my stx 38 with black deck is 7 years old , have had no problems other than replaced the belts last year, only mow about an acre, but mow it every week about 8 months out of the year, change the oil, lube where it has a place to, keep battery connections, etc clean and you should get several years of use with limited problems
Vern
12-24-2003 19:29:28
 Re: Re: LT133s in reply to john669, 12-24-2003 15:22:13
john669;
I have the yellow deck & have had both wheel brackets break out of the deck, bearings fail in both blade spindles, idler pulley brackets bend, & a piece from the r/h blade go through the deflector chute. I had an older model 60 that I ran for years with less trouble. I don't think the new deck is as thick as the old one.
Vern
john669
12-25-2003 19:26:05
 Re: Re: Re: LT133s in reply to Vern, 12-24-2003 19:29:28
maybe I should feel lucky, sounds like I may have the only good one made, or maybe I need to sell it before I have problems, it is 7 years old
john669
12-26-2003 14:15:38
 Re: Re: Re: Re: LT133s in reply to john669, 12-25-2003 19:26:05
well, didn't sell it quick enough, while mulching leaves today, idler pulley bearing locked up, looks like it's going to cost me about $18 to fix it, maybe it won't happen again for another 7 years, I sure hope so
Vern
12-28-2003 22:30:06
 Re: Re: Re: Re: Re: LT133s in reply to john669, 12-26-2003 14:15:38
FYI;
All the bearings on my deck are the same & they cost about $6.00. They also come sealed, semi-sealed, or open.
Vern
