bolens walk behind
Dale in Ar
09-14-2003 18:44:29
I just bought a Bolens walk behind at a tractor show this weekend,need info.I don't know much about it,except it is a walk behind and the name on the gas tank said"Bolens Husky".It has a wisconsin motor on it and has a mag.It also has clutches for each drive wheel and is chain driven.Now can anyone tell me the model number,where to find the serial number,or anything else about it ?
Scott
09-15-2003 17:23:13
 Re: bolens walk behind in reply to Dale in Ar, 09-14-2003 18:44:29
The early 1940's had the serial# plate on the handle bar, the later ones had a plate riveted between the engine and handles on the flat surface, from 1947 on the serial# started with a letter (G if gardener model), Bolens did not publish serial# charts so if it has the original engine that serial# can be dated.
dave b .
09-15-2003 13:17:29
dale i cannot tell you the model number but i can tell you what you have. it is a bolens huski gardener. your motor is a wisconsin . abn. 4/12/ hp. i owned 2 of these big tractors. they atre. very heavy . and them are steering clutches. they . were made from 1946. to about 1951. they arent a whole lot of them in the us. they were mostly imported to other countries. in eastern uorpe. russia germany hungry. and also in the middle east and japan . hiope this helps dave b .
