Gravely L series sickle mower motor tran
dean
10-22-2002 17:29:22
Anyone know much about the L series 1960 or so thru 67? (Has tranny built in)I have one that the powertrain slips now pulling up a hill. Whats involved in this type repair? I have rebuilt top end and runs good although know nothing about the tranny. Thanks.
Rich
10-24-2002 21:40:01
 Re: Gravely L series sickle mower motor tran in reply to dean, 10-22-2002 17:29:22
You might just need the clutch adjusted some. The rod that the fwd/rev lever is attached to, follow it down to where the springs and the lever on the side of the transmission are. Without the engine running, when you pull the lever back to engage forward the spring should have very little space between the coils. The same is true when reverse is engaged( coils tightly compressed). You may need to adjust the nuts on the rod to get the coils compressed tighter thereby engaging the clutch tighter. If you need more info check out the yahoo site or send an email and I'll try to be of more help. Good Luck.
Rich
gene gullo
10-23-2002 18:26:14
Sounds like your front clutch is gone. It located behind the front end casting. Go to the Yahoo gravely club website there should be some manuals you can down load. All model L's are pretty much the same and the parts are interchangeable. E-mail me if you have any more questions.
