Gravely 7.6
Gene
09-08-2002 18:09:14
I have a gravely 7.6 that will not slow idle. At fast idle and open trottle it runs fine. At a slow idle it starts making a popping sound through the carburator. This only happens a slow idle. I have gone through the carb and mag and the engine has been timed to specs. Any suggestions would be appreciated.
venda
09-09-2002 14:09:11
 Re: Gravely 7.6 in reply to Gene, 09-08-2002 18:09:14
Sounds like it is too lean. It may be something as simple as a bad spark plug. Do you have an idle mixture screw? If so try to adjust it out to give a richer mixture. Or there is always the chance that your engine is low on compression from leaking valves or worn rings. ?? Good luck.
