Gilson tractor mower deck belt idler pully
Mickw
06-11-2002 10:42:09
Does anyone know where I can get replacement idler pullies for a circa 1983 Gilson. I think they went out of buisness. Pully is about 4.5" dia with 3/8 inch mounting hole. The bearing is shot. Don't need an exact match as I could lengthen / shorten belt.
Thanks in advance
Fish
06-11-2002 11:17:29
 Re: Gilson tractor mower deck belt idler pully in reply to Mickw, 06-11-2002 10:42:09
Most mowers shops should be able to match you up
an idler pulley that matches real close, but Gilson parts can still be bought from a Lawnboy dealer. Fish
NICK
08-30-2002 14:29:39
 Re: Re: Gilson tractor mower deck belt idler pully in reply to Fish, 06-11-2002 11:17:29
I HAVE A 1974 WARDS[GILSON TRACTOR] I NEED A DRIVE SHAFT.WHEN IT BREAKS I ALWAYS HAVE TO REPAIR IT.DO YOU KNOW WHERE I CAN BUY A NEW ONE
Mac
06-11-2002 11:00:52
Not knowing the exact situation, I have drilled out the rivets and separated the pulley and installed a new bearing. Used small bolts to reassemble the halves.
