Kohler CV14S has intermittent spark
Bob Longenecker
04-04-2001 09:37:45
My Craftsman Lawnmower with a Kohler engine (model #CV14S) has an intermittent spark. It will start, then run for approximately 5 minutes and then quit. When I attempt to restart the spark is gone. If I let the mower sit for a day, it can then be started. This is a very consistent pattern.
Any suggestions will be greatly appreciated
wrenchman
04-07-2001 03:16:06
 Re: Kohler CV14S has intermittent spark in reply to Bob Longenecker, 04-04-2001 09:37:45
had exactly same problem,clue is runs fine till warms up,replaced coil(magneto),solved problem.when coil warmed up it shorted out.
Bob Longenecker
04-09-2001 05:24:58
 Re: Re: Kohler CV14S has intermittent spark in reply to wrenchman, 04-07-2001 03:16:06
Thanks guys - that was it - replaced the coil (magneto/ignition unit) and all is fine. I appreciate the help.
Bob Longenecker
04-05-2001 07:31:34
Jim: Thanks for the response. Yes - it is an electronic ignition.
Jim S.
04-05-2001 07:15:37
Bob, my danged book is at home and I'm at "work"!!! So I don't know if it's electronic ignition or not.
Anyhow, here's stuff to check:
1. Bad plug wire.
2. Loose/grounding connections in kill switch circuit.
3. Bad condenser (point ignition).
4. Bad magneto.
5. Bad electronic module/magneto.
Hope this gets ya on the right track. I'm just gonna have to break down and buy TWO SETS of books!
Kevin
09-30-2003 05:09:51
 Re: Re: Kohler CV14S has intermittent spark in reply to Jim S., 04-05-2001 07:15:37
You forgot to list one thing on your list of things to check.
A shorted winding in the stator can also cause the tecumseh ignition modules not to spark.
Or even a bad brush plate on an electric starter can rob all the voltage from the ignition system and cause this same problem.
I suspect the stator is bad and not supplying full voltage to the ignition module.
David Shinn
03-11-2004 13:57:57
 Re: Re: Re: Kohler CV14S has intermittent spark in reply to Kevin, 09-30-2003 05:09:51
Is a CV14S a pull-starting engine? Also, is an ignition module related to the coil? What is the model number to the coil for a pull-starting engine?
