Hahn-Eclipse Snow Giant Parts
Jules Rydarowsk
02-22-2001 18:58:50
Looking for a dealer that has left over Snow Giant parts, Model 24" Standard CH-584-5 Stock #652.
Would like to replace the tires and/or tires and wheel.
Peter M
12-11-2005 06:16:59
 Re: Hahn-Eclipse Snow Giant Parts in reply to Jules Rydarowski, 02-22-2001 18:58:50
I have a Snow Giant and I believe it needs a new carberator or mine rebuilt. Does anyone know if there is parts still available, or should I sell whole machine for parts???
brian menard
01-23-2006 09:07:29
 Re: Hahn-Eclipse Snow Giant Parts in reply to Peter M, 12-11-2005 06:16:59
I am also looking for parts.. not an easy task. If you do want to sell your snow giant please let me know!!
Jim Glasener
10-15-2004 19:13:12
I am in need of an owner's manual and would like to know if it has an air cleaner and how to obtain one. Thank you Jim
John Mulready
01-01-2006 12:55:08
 Re: Hahn-Eclipse Snow Giant Parts in reply to Jim Glasener, 10-15-2004 19:13:12
Jim, Just wondering if you ever got hold of a manual for the Hahn Eclipse Snow Giant. I am trying to fix mine but need to I.D. part#/desc
Don Altobelli
06-10-2004 22:12:12
Just bought some solid wheels for my 20 inch Hahn Eclipse snowblower from www.surpluscenter.com
Brian Hayward
12-04-2003 06:54:36
I am in need of wheels/tires for my Snow Giant. Did you have any luck finding spares? Have you tried chains?
Regards,
Brian Hayward
chris crook
03-13-2005 08:10:58
 Re: Re: Hahn-Eclipse Snow Giant Parts in reply to Brian Hayward, 12-04-2003 06:54:36
I have a 1970 snow giant. I need to put anew belt on . Is this a big job?.Can anyone tell me how to do this or does anyone have a repair manual? Other than that it runs great!
Thanks Much
Chris
Gaston Guénette
03-14-2003 08:20:28
Have you identified a dealer that would have left over Snow Giant parts? I have a 24-inch Deluxe UH-584-7 (stock No. 689) with a broken auger clutch drive). One of my recourse is to have the part machine shopped, but it would be easier if I found one. Thanks.
John Mulready
12-31-2005 09:53:46
 Re: Re: Hahn-Eclipse Snow Giant Parts in reply to Gaston Guénette, 03-14-2003 08:20:28
Dear gaston, I also have a Snow Giant UH-386-8 but I am Missing the manual that gives the part numbers/descriptions. I believe it has a broken bearing for the auger drive. Any suggestions?
Dale Mansfield
07-27-2002 18:54:44
Just wondering if you ever had any luck locating parts for your Snow Giant? I too am in need of a part-a fan clutch lever to be exact. Any thoughts?
Thanks
Jim S.
06-26-2002 08:14:40
 Re: Cub cadet gas starvation in reply to Don J., 06-26-2002 04:17:17
1.) Fuel tank vent plugged? Try running it with the cap unscrewed a bit.
2.) Does it have a fuel pump? I seem to recall they do. Bad diaphram in it?
3.) I also seem to recall it has a fuel shutoff solenoid. Problem there -- sticky?
4.) Not a gas problem, maybe? Have you checked for spark by pulling a plug and cranking it right after it dies?
5.) Leaky or sticky valves? Your need to use starting fluid makes me wonder about that. At 2 years old, maintenance would have to have been poor for that problem to pop up.
Good luck.
