Green Machine Electric Cultivator
John
04-24-2000 15:15:49
I need a replacement tine for an electric Green Machine Garden Cultivator.
Manufactured by HMC of Long Beach, CA
Model 700
David ellis
06-18-2004 15:46:51
 Re: Green Machine Electric Cultivator in reply to John, 04-24-2000 15:15:49
I could not find a replacement tine so I went to the local welding shop and had one made in 1/2 hour for $10. The chap used 1" flat steel folded in two, used the other tine as a guide to bend it to shape and drilled the hole for the bolt. Works fine.
DE
Gerald J. Hock
08-12-2002 09:20:15
I have a Green Machine cultivator, but I need a gear that broke on it. Part number on the gear is 950301, its the large gear that runs next to the electric motor gear. Please advise where I can purchase this gear. Thank you for your help.
Jim Hafer
04-09-2002 17:14:41
as in this unresponded request I also need a replacement tine for a green machine electric cultivator
Robert Giroux
04-23-2002 06:34:15
 Re: Re: Green Machine Electric Cultivator in reply to Jim Hafer, 04-09-2002 17:14:41
I also need replacement tines ... Any luck finding some?
Leilani Freeman
05-15-2002 21:41:34
 Re: Re: Re: Green Machine Electric Cultivator in reply to Robert Giroux, 04-23-2002 06:34:15
I need a lugnut that holds on the tine for the same model cultivator---any luck?
Joanne
07-29-2004 17:08:39
 Re: Re: Re: Re: Green Machine Electric Cultivator in reply to Leilani Freeman, 05-15-2002 21:41:34
Do you still have those tines for the Green Machine cultivator? Do you know where I can get them?
Thanks,
Joanne
kevin caudill
10-14-2003 02:52:02
I have tines instock
606-561-4983
