Compression Troubles?
Alan D
02-23-2003 01:52:33
I have long been looking for the solution to my 1958 Dextas RPM troubles, when the tractor starts its gains and loses revs, after awhile the revs level out but if i go to move the trottle it gains and loses revs again and then eventully levels out, I have also noticed on idle that when it is gaining and losing revs it will puff out some smoke, its kind of blue in colour, could this be a compression problem with one of the cylinders?
jim k
02-23-2003 19:24:03
 Re: Compression Troubles? in reply to Alan D, 02-23-2003 01:52:33
Alen check the cheep stuff first could be a fuel problem pluged filter; maybee an air leak loose fuel line etc. after that i would look at the govener' check that last. good luck
Burrhead
02-26-2003 19:03:58
 Re: Re: Compression Troubles? in reply to jim k, 02-23-2003 19:24:03
I'm with Jim. I don't think you have a serious problem.
The most common cause of the rpm problem is a sticking gate in the air intake. Just a little dirt in the tube and the gov don't work right.
If the flap, vacuum line and gov diaphram check out okay I would check the air cleaner itself. If sludge builds up in the wire mesh it effects the gov.
