1927 F Transmission Oil??
Dave
11-20-2001 12:34:51
What is the recommended oil to be used in the Transmission of a 1927 Fordson "F"? The manual seems to suggest heavy motor oil. We use SAE 30 in the engine just because it seems to make sense
Also, will using any thinner oils or Marvel Mystery for a brief period loosten up the clutch plates that always get stuck?
Thanks!
ADAM
11-21-2001 19:53:24
 Re: 1927 F Transmission Oil?? in reply to Dave, 11-20-2001 12:34:51
Factory fill was 600W gear oil. Today any 80w-90 or 85W-140 gl-5 gear oil if good. You really should use a gear oil to protect the worm drive system. A clutch rebuild that restores the cup to the clutch disks will solve your clutch problem.
