1923 Fordson model F Govenor Adjustment
Bob Camicia
10-23-2001 17:32:28
I have a 1923 Model F with a Holley Model 280 Vaporiser with a Fordson "Govenor" housing attached to the Vaporiser. My problem is that I can't get the combination Govenor/Vaporiser adjusted to maximize the power out of the engine. It is not a spark-advance or fuel nozzel adjustment issue, the vaporizer doesn't seem to be getting a wide open throttle when it's under load, and consequently doesn't have the kind of power that it should have. It will barely move in 3rd gear. Can someone enlighten me on the Govenor/Vaporizer adjustments?
Theman
10-24-2001 06:12:09
 Re: 1923 Fordson model F Govenor Adjustment in reply to Bob Camicia, 10-23-2001 17:32:28
I have a '23 model F with the Holley vaporizer but it doesn't have the governor. With what I've experienced on mine, you might check the opening of the butterfly with the engine off and make sure it can fully open. If the butterfly does open up, then your governor may not have enough spring tension to overcome the flyweights which are trying to slow the engine down. If the butterfly can't open fully with the engine off you may have a high-speed stop screw that needs to be backed off or quite possibly a linkage problem.
