1928 Fordson F fuel sys. problem
Debbie Nix
08-04-2001 19:41:07
Hi, our neighbor bought a 1928 Fordson F last weekend. The problem we are facing is that fuel is getting to the float bowl but there doesn't seem to be enough vacumn do draw it up to the carb. Any info. on where we could find a diagram or other things to check? We can get it to run by spraying gas into the carb. intake. We've already gotten alot of info. just by going through your board. Thank you,
Debbie
John
08-05-2001 06:23:04
 Re: 1928 Fordson F fuel sys. problem in reply to Debbie Nix, 08-04-2001 19:41:07
Debbie what kind of carb. or vaperizer does the tractor have A holley or a kingston.
Debbie
08-05-2001 08:12:14
 Re: Re: 1928 Fordson F fuel sys. problem in reply to John, 08-05-2001 06:23:04
I'm told it is a Kingston. I have a photo scanned if that would help identify. Thank you
Fordson exchange
09-25-2001 20:19:39
 Re: Re: Re: 1928 Fordson F fuel sys. problem in reply to Debbie, 08-05-2001 08:12:14
Debbie,
Not knowing for sure what you have for a carb, off hand I'd say you may have a deteriorated vapor tube. Did you scan the photo you mentioned?
RLL
