23 fordson
j.lahti
06-13-2000 06:58:43
my tractor mechanic is restoring a 23 fordson
and upgrading the magneto/ignition to a distributor. it is the last part he needs. any
ideas on where to find one. he says that the
distributor was an upgrade. help
Fordson Exchange
06-17-2000 07:50:02
 Re: 23 fordson in reply to j.lahti, 06-13-2000 06:58:43
As you probably know, the 23 Fordson was not manufactured with a distributor ignition. However, you may be suprised to learn that the first production Fordson built on July 12, 1917 came off the line with a distributor. During reconstruction of my 'Hybrid Fordson' (1923 F) I considered adapting one. Lang's model T parts in Winchendon, MA has the model T version that should fit your needs (800-872-7871).It may rquire some very minor customizing. If you can find the late Peter Letourneau's 1917-1928 Photo Fordson Archive book, check out page 27. I could have won a wager at the Ford/Fordson Show at Kinzer PA a couple of years ago if I had taken the book along. Good luck and keep in touch. RLL
