Removing front crank bolt on a '64 FSM
buckstrand
08-15-2007 13:56:19
I need to replace the front oil seal on a 64 diesel FSM and therefore have to remove the front crank bolt. Are there any tricks to "locking up" the crank so this bolt can be removed and eventually replaced without having to remove the oil pan or messing anything up? Does anyone know what the torque spec is. I have a service manual on order but it might be a week or so before I see it.
thanks in advance
mechanicfred
08-15-2007 19:40:36
 Re: Removing front crank bolt on a '64 FSM in reply to buckstrand, 08-15-2007 13:56:19
put the trans in gear and set the brakes!
cdmn
08-19-2007 18:02:37
 Re: Removing front crank bolt on a '64 FSM in reply to mechanicfred, 08-15-2007 19:40:36
Keeping safety precautions in mind, you could set the wrench on the nut and then hit the starter motor to kick it loose.
buckstrand
08-18-2007 19:36:27
mechanicfred said: (quoted from post at 19:40:36 08/15/07) put the trans in gear and set the brakes!
thanks mechanicfred. I had tried that but there was too much play. I was trying to remove the balancer without removing the radiator. I ended up removing the radiator and everything became much simpler. thanks again
