Fordson Tractors Discussion Forum
fuel line ferrule dexta
zerolash
06-04-2006 17:46:39
can anybody tell me if the fuel line ferrules are still available? these are the little ring at the end of the fuel lines at every connection
all are orignal and good on my dexta except the tank to lift pump line, I use 1/4 od copper tube
and a regular plumbing ferrule but it is to small to seal so I wrap it with a little teflon tape but after about 10 hours of use it seem to be a source of air in my fuel system causing me to loose prime and stalls I just need a more perminate solution
dextad
06-21-2006 10:58:13
 Re: fuel line ferrule dexta in reply to zerolash, 06-04-2006 17:46:39
I ended up putting a correct sized fitting that has a nipple for 1/4 hose into the tap. then ran approved fuel hose to the cut end of the 1/4 pipe from the lift pump. put 2 hose clamps, no leaks yet. it also allows placement of an inline filter as an additional precaution, just cut the hose and put the filter in.
later,ernest
dwol
06-08-2006 14:33:15
I converted to an inline fuel pump, and used regular fuel hose from kragan. Works fine. I never had any luck with the ferrels either.
