Fordson Tractors Discussion Forum
fordson 5000 ( s. major? )
souNdguy
04-12-2006 17:15:51
How does it compair with the ford 5000? I saw one at an auction.. thay had just labeled it a ford 5000.. however sheet metal caught my eye, and knew it was'nt plain 5000. They listed a very low hp number.. like 48.. didn't sound right. Info? general or otherwise. Anyone own one and a ford 5000.... differences?
Soundguy
Majorman
04-12-2006 23:28:46
 Re: fordson 5000 ( s. major? ) in reply to souNdguy, 04-12-2006 17:15:51
They are a totally different tractor. In my humble opinion they were far better than the early 5000 and in operation, over here, performed far better. They did not have the range of gears or the strenght in the hydraulics but there was more metal used in the whole tractor. The 5000 was actually 5cwt lighter!
The HP was 55 and the torque figure was higher than the first "true" 5000.
We were sorry to see them replaced and it took nearly three years to get the 5000 right. Again, at that time the 4000 was a far better tractor than the 5000 but time marches on and they finally got the new models better, but for easy of working, the Super Major 5000 took some beating.
I have seen about 1400 hp put through the standard gearbox and rear axle in tractor pulling. there used to be one around fitted with a Rolls-Royce Merlin engine from a WW2 Spitfire.
souNdguy
04-13-2006 04:58:06
 Re: fordson 5000 ( s. major? ) in reply to Majorman, 04-12-2006 23:28:46
Hmm.. A gas and diesel 5000 have about 71-72 hp. Are we maybee talking about different units?, Ie the 5000 that you are using for comparison to?
Soundguy
Majorman
04-13-2006 10:38:24
 Re: fordson 5000 ( s. major? ) in reply to souNdguy, 04-13-2006 04:58:06
The early 5000 was 67 HP, 66 dead and one very sick! The later models were up to 75 HP.
The quoted torque figures from the Ford demonstrators handbook are 5000 = 170 @ 1400, Super Major = 180 @ 1200. So we gained 13HP but lost the ability to lug down under load.
In fact the 5000 was nearly 20lbs/ft light on its nearest rival the Massey Ferguson 175. This really showed up at demonstrations.
We had to handicap the 4000 if we were demonstrating the two side by side as the 4000 would do more work in an hour on less fuel.
souNdguy
04-13-2006 10:55:00
 Re: fordson 5000 ( s. major? ) in reply to Majorman, 04-13-2006 10:38:24
According to my ford spec sheet. the gas 5000 was 71hp net, and the diesel was 70 net, rpm range was 2100.
Torque on a fully equipped engine, at rated speed was 171 gas, and 175 diesel.
Max torque on the gas was 206 at 1100 rpm, and for the diesel, 199 at 1300 rpm. Both observed figures.
As far as i know.. the 5000 was one of the best tractors ford turned out. I can pretty much say that a 5000 would rip a 4000 in half. Around here, people use 5000's to mow with 10-15' mowers.. I don't know anybody mowing with a 15' mower on a 4000.. I do believe I've seen a 4000 creeping along at max rpm /1st gear with a 10' mower before though.
Having driven 4000's.. both the old 4 cyl ( updated 801 clone ) and the later models, and later 5000's I can say that they are just not inthe same class... not even really close. Look at the lift specs...
I'm really kinda surprised at the 'lower than 4000' opinion i see here. have never heard that before...
Soundguy
Majorman
04-13-2006 23:54:41
 Re: fordson 5000 ( s. major? ) in reply to souNdguy, 04-13-2006 10:55:00
I think your talking about 5000's after 1968 and I'm talking about the one that came out in 1964. I was involved in demonstrating them at the time and Ford issued us with a book with all the specs. and comparisons of all the opposition tractors. In 1968 they even gave all the service and sales staff a present of Ford goodies and a letter of thanks for sticking by them with such a poor tractor range. After 1968 they increased the HP in the whole range and called the tractor "Ford Force". Then we had a tractor to sell!!
I would agree with you that this was a really good machine. I never went away from a Ford dealer and believed they would get it right in the end but the years from 1964 to 1969 were a great disappointment to all over here including the Ford team at Boreham. Years later, they are now prepared to write in our vintage mags. what they really thought!
souNdguy
04-14-2006 13:05:12
 Re: fordson 5000 ( s. major? ) in reply to Majorman, 04-13-2006 23:54:41
Makes sense now.. I'm on the same page now. I was deffinately thinking of the 68-75 period.. not the early ones.
Soundguy
