Fordson Tractors Discussion Forum
dexta petro idle
Robert Schem
11-21-2005 08:38:52
I can't get my dexta to idle .If i manually push on the carb linkage it will slow to low idle and die.could this be loose linkage problem?
mikes dexter
12-05-2005 15:35:14
 Re: dexta petro idle in reply to Robert Schem, 11-21-2005 08:38:52
try to adjust the throttle linkage under the hood or under the steering wheel its probally out of adjustment let me know if it works
Nicholas Epperson
11-27-2005 18:02:54
If the tractor runs well wide open, the problem may be in the throttle shaft on the carburator. Sometimes it will get slack "up and down motion" from long term wear. This will allow air to bypass the butterfly and idle rough or not at all.
