1926 fordson
Bill Dean
01-20-2000 14:11:42
i am restoring a 1926 fordson that was a basket case engine is done and i am starting to put back togather cannot remember how the felt seal with the sheetmetal cup fits on the crank at the fan pully end felt to the engine or to the next casting help
Theman
01-27-2000 08:39:55
 Re: 1926 fordson in reply to Bill Dean, 01-20-2000 14:11:42
I checked my copy of a Fordson owner's manual and it said nothing about the sheet metal cup. There were no details on assembling the front casting at the crankshaft and there wasn't a clear cutaway showing every part. There was an X-ray type rendering that had arrows pointing to some of the parts. The felt seal was represented but there was nothing to show if it was in a cup or not.
Bill
01-28-2000 05:09:08
 Re: Re: 1926 fordson in reply to Theman, 01-27-2000 08:39:55
Thanks to every one that replied it is nice to know that there are still some pretty nice people out there old tractor collectors are in a class of thier own Bill
adam
01-24-2000 17:06:46
the only front seal for the engone is a two piece felt that fits in the oil pan and the engine block, nothing on the outside.
Bill
01-26-2000 07:43:24
 Re: Re: 1926 fordson in reply to adam, 01-24-2000 17:06:46
I must have the legendary left over piece. the I.D. of the metal cup the felt sets in is the same as the crank output shaft at the fan pully end. It looks like it would onto the crank or maybe the rotor and under the casting thatsupports the front axel.
Don(CO)
01-27-2000 09:04:42
 Re: Re: Re: 1926 fordson in reply to Bill, 01-26-2000 07:43:24
Bill, A picture would be worth a thousand words here. I concur with Adam on the original Model F seals. I wonder if someone has used a redi-sleeve or speedy-sleeve over the seals if the casting was worn or scored. Just a thought.
Don
