Fordson Tractors Discussion Forum
help to identify a fordson tractor
Tom Mcc
01-24-2005 17:25:15
I just bought a old fordson tractor its serial is 1314844 I was told it may be a dexta but cant find it in the serials listed , it looks simlar to a 9n or 2n but has both brakes on rhs and clutch on lhs
it is of course a kero petrol model
any help would be appreciated email Me or list reply here thanks for all help given
cdmn
01-28-2005 17:37:20
 Re: help to identify a fordson tractor in reply to Tom Mcc , 01-24-2005 17:25:15
just about all of the dextas had 3 cylinder diesel engines. However, a very small number used "Standard" petrol engines, same as used by Fergusons. Is it Blue, Gray, or Red? Take a look at some of the pictures posted on this site.
Leroy
01-26-2005 17:37:25
I think more information is needed to identify, size of tires, type of transmission, headlights, in grill or not, any other distinguishing features, hydrolics, type of adjustment on wheels
ron algiere
01-24-2005 18:01:07
according to this chart i'ts somewhere around a 54 or 55 new major with a MarkI engine here's the sight Link
Roger Flynn
01-25-2005 09:40:40
 Re: help to identify a fordson tractor in reply to ron algiere, 01-24-2005 18:01:07
Hey Ron, sorry to butt in with a different thread but I know you have the exact same tractor as mine.
My son-in-law is a heavy equipment operator and told me that my backhoe would use a 15w40 engine oil, foolishly I listened to him and added it.
Now I have a foamy mess.
What do you use in yours?
ron algiere
01-26-2005 05:45:23
 Re: help to identify a fordson tractor in reply to Roger Flynn, 01-25-2005 09:40:40
no , no, no, dump all the oil you can. disconnect the lines from the pistons if you can, then add about 5 gallons of all weather hydraulic fluid or enough to get the cylinders working, dump that fluid then add full amount of all eather hydraulic fluid to the system and you should be OK, don't forget to clean out the filters and strainers if you have them. The reason for going through all this is, hydraulic fluid will not attack the seals in the pistons, motor oil will! Good luck, where are you located?
Roger Flynn
01-26-2005 12:32:03
 Re: help to identify a fordson tractor in reply to ron algiere, 01-26-2005 05:45:23
Yea, I kinda figured as much, so much for my "expert" son-in-law.
Thanks for the confirmation Ron, will Hy-Tran work or not?
I'm located about 80 miles NE of Los Angeles, in the San Bernardino Mountains.
ron algiere
01-27-2005 05:05:22
 Re: help to identify a fordson tractor in reply to Roger Flynn, 01-26-2005 12:32:03
Roger I'm not familiar with hy- tran, just check the specks, I'm a NYer myself, I hope you guys are getting some descent weather out there Good Luck!
Roger Flynn
01-27-2005 08:06:18
 Re: help to identify a fordson tractor in reply to ron algiere, 01-27-2005 05:05:22
Right now, 70 degrees & sunny!!
I just bought 15 gallons of "RYKON" ISO 46 AW, that should do it.
If you or anyone else need any unobtainable parts made for your FPM I own a CNC machine shop, we make military diesel motorcycles www.f1engineering.com
ron algiere
01-29-2005 06:16:18
 Re: help to identify a fordson tractor in reply to Roger Flynn, 01-27-2005 08:06:18
Thanks for the offer I WILL be in touch
